high mount stop lamp
Old Mar 12, 2015 | 06:42 PM
hillynd's Avatar
Default high mount stop lamp
Hi all- I just bought a 2005 V70 wagon and there were no error messages about stop lamps when I bought it. Now, I have a "check stop lamp" message. Both left and right are ok. On the high mount center, none of the bulbs light up. Is it a single unit that can fail or is it a series of bulbs. Also, any advice on how to check if it is a relay or switch and not the lamps themselves?
Thanks.
Old Mar 12, 2015 | 10:09 PM
JamesG's Avatar
The CHMSL may be LEDs. First check the fuses in the rear. In my 2004 there are two fuses labeled "brake lights", #3 15A and #14 7.5A. If I had to guess, I would say #14 would be the CHMSL. Check your rear fuse panel for such a fuse.
Old Mar 13, 2015 | 12:16 AM
damien360's Avatar
Check the wiring harness on the left side of the tailgate. A cut wire is the only time ive ever seen the center brake light go out
ankitjuthani
Jan 5, 2012 05:27 PM
sas80
Aug 11, 2011 08:57 AM
JohnB7
Jan 6, 2011 05:52 PM
vwbusman
Oct 28, 2009 08:12 PM
chad951
Jan 28, 2008 07:22 AM
