Rough Ride
Old Oct 29, 2006 | 10:58 PM
delrosen's Avatar
Default Rough Ride
Hi all, just purchased a 98 V70 AWD. Love the car but there seems to be a vibration at around 60 miles per hour, actually it feels like driving on a rough roadway. Once I hit around 65, the ride smooths out again. Any help will be appreciated. Thanks.
Old Oct 29, 2006 | 11:43 PM
Default RE: Rough Ride
Could be wheels out of balance.
Could be a bad tire.
Could be a bad driveshaft.
Old Nov 1, 2006 | 08:37 PM
delrosen's Avatar
Could a bad tire/out of balance tire cause this conditions just between 55 and 65 MPH? Thanks
Old Nov 2, 2006 | 07:09 PM
JimKW's Avatar
Yes - Out of balance almost alway causes vibration at around 55 to 60 mph. Might also be a bent wheel. I have one and it gets worse at higher speed though. I would have the tires balanced and they will let you know if you have a bad tire or bent wheel if you go to a good tire place. I use NTB.
Old Nov 18, 2006 | 11:05 PM
delrosen's Avatar
Had the tires balanced and checked for bends. Unfortunately, the vibration still exists. Was told maybe a motor mount? Does this sound right?
[quote]ORIGINAL: JimKW
Old Nov 19, 2006 | 12:40 PM
Possible motor mount but also possible Driveshaft.
Common to go bad on the XC models.(Driveshaft)
Old Nov 20, 2006 | 12:30 AM
delrosen's Avatar
How expensive is a motor mount and a drivshaft?
Old Nov 20, 2006 | 12:31 AM
delrosen's Avatar
How expensive is a motor mount and a driveshaft?
Old Nov 24, 2006 | 10:18 AM
Motor mount installed probably about $160.00 or so Driveshaft about $1600.00 to $2000,00 installed.
Camden
Aug 6, 2010 12:42 PM
dman777
Apr 9, 2009 08:19 PM
erndawg
Jun 5, 2007 04:31 PM
delrosen
Oct 31, 2006 03:04 PM
bus stop
Nov 12, 2005 08:06 PM
