What do i do next????
Old Jun 8, 2017 | 06:53 PM
Bpc576's Avatar
Default What do i do next????
alright guys. im loving my 2000 s40. so far it has a 3 inch downpipe to a 2.5 inch straight pipe. an upsolute tune and 12 lbs of boost. but what do i do next. i had a cone filter intake from eurosport but it killed by low end so i went back to the airbox...
what would you do next?? let me know!
Old Jun 11, 2017 | 05:19 PM
did you add larger injectors? Are you still running the 12T turbo or have you upgraded to the 14T yet? For my two cents, I'd assume you are now in the 200-250 HP so I'd start working on the handling - For wheels, you can run OEM 16s or upgrade to 17s with aftermarket. I'd also consider shocks and perhaps springs (ie Bilsteins+HRs?) and I believe you may be able to find a fatter rear sway bar and perhaps a strut tower brace.
I also personally hate the steering wheel on my S40 but not sure what would fit as a replacement that would retain the drivers airbag.
Old Jun 11, 2017 | 06:20 PM
Bpc576's Avatar
i dont like my wheel either. i have cast internals and not forged. so im running a strut bar. i was thinking about adding some HR springs to lower it a bit. i havent done the 14 t. yet. i was thinking a boost controller to bypass the TCV but i dont know if that will throw codes. i dont want to increase boost. but i notice the tcv holds the boost at 5 psi until i push the pedal down. it doesnt let the turbo spool freely. also i cant find the specs on the current wastegate spring psi. I would love if i could run a boost controller and get my full boost all the time. im not running bigger injectors. should i be running them with the tune and exhaust im running? will the ecu compensate for the larger fuel injection?
Old Jun 20, 2017 | 09:53 PM
check out the ARD web site. they have a choice of injectors and boost control parts - and can probably talk to your tuning questions, and whether you should install a Cel-Boss to help prevent codes.
daninickels
Dec 15, 2007 11:24 AM
Moon
Dec 6, 2007 01:40 PM
mike367
Sep 21, 2007 09:16 AM
Patdon10
Aug 1, 2007 04:27 PM
Clueless Scott
Jul 1, 2006 10:39 AM
