740 wagon not starting again
Old Jun 8, 2008 | 06:18 PM
wehashi21's Avatar
Default 740 wagon not starting again
i own a 92 740 wagon, ive changed everything and spent more than the cars prob worth, to fix, the not starting, low idle problem. today i went out to my car and not its not even turning on, its not the battery, cuz my radio, and all my lights work, it just wont turn over, its not clicking, but it ran fine yesterday. HELP please, does anybody know whats wrong?
Old Jun 8, 2008 | 11:23 PM
wojeepster's Avatar
Default RE: 740 wagon not starting again
It is not magic. I have been in the same place as you and have spent tons of time and money trying to get it right and always eventually did. I recommend you buy a book by Tracy Martin, "How to diagnose and repair automobile electrical systems" It is dirt cheap I think it is $17 on www.amazon.com I have gotten very good at fixing electrical systems since then.
Now for my guess, and this is only a guess. Sometimes the electrical part of the ignition switch goes bad. Get a digital multimeter (Harbour freight has a backlit one for $3.77) If it doesn't crank clean the battery terminals and charge the battery fully before doing anything else. Then check for spark and check for gas. As you have already found out just guessing and replacing stuff gets expensive fast and is not likely to solve the problem. Read the book (it will save you thousands!) get a volvo wiring diagram for your car and conquer the world.
Old Jun 9, 2008 | 01:59 AM
wehashi21's Avatar
i just changed and fixed the ignition last week, so i know its not that, could it be my starter by chance?
Old Jun 9, 2008 | 09:19 AM
wojeepster's Avatar
It could be (it could be alot of different things)but is more likely a loose or bad connection or a battery that is discharged. You can measure voltage at starter when cranking and measure voltage on ground return when cranking.Ground return should be close to zero, power to starter should be around 12v.
Old Jun 14, 2008 | 12:27 AM
Glockness's Avatar
i just had this problem. i have a 92 turbo wagon. its a relay. check under the fuse box. there are some GIANT fuses. they are relays. GENTLY!!! GENTLY!!!! GENTLY!!!! press down on them to make sure they are "seated" correctly. if it still doesnt work. replace the fuel pump relay.
Old Jul 15, 2008 | 10:25 AM
fredbyte's Avatar
Visit www.stepbystepvolvo.com. It has a diagnostic guide for 740/940 no-starts. wojeepster is right. Make sure you have a good battery! A battery might power lights but not have enough cranking power to turn the starter.
cioara
1998-2000 model year V70
Sep 24, 2014 07:25 AM
240nut
Apr 1, 2013 11:59 PM
rupert77
Jan 24, 2009 05:13 PM
crystalfleet
Jan 16, 2008 07:30 PM
BostonC70
Mar 26, 2007 03:50 AM
