'92 Volvo 240 Odometer not working!
Old Nov 16, 2021 | 08:14 PM
edgarisaacc's Avatar
Default '92 Volvo 240 Odometer not working!
Hello, today I replaced the odometer gear with the aftermarket gear available through IPD. My original gear did not appear broken. It felt a bit stuck but with a little push it spun. I installed the new one anyway.. After re-installing the cluster back into the car unfortunately my odometer still does not spin! Anyone else have a similar issue? I know that 240 odometers stop working often around 150,000 miles.. any info appreciated! thanks.
Old Nov 16, 2021 | 08:38 PM
91Volvo240survivor's Avatar
One of the reasons that 240’s lack value is this a well known issue. Other cars like 78-1985 RX7’s are also not as valuable in that it’s well known it takes about 45 seconds to undo the odometer cable. If you really want it fixed for good. See below
www.sweedishcarpartsdotcom. $375 for a full rebuilt
Old Nov 17, 2021 | 08:35 PM
volvodriver99's Avatar
I had a similar issue where I swapped out the gear, which didn't appear to be broken as well, and it didn't fix my odometer issue. I ended up finding a used cluster on eBay, swapped out the whole thing, and it worked for a day... then that gear in it actually busted... I swapped out the gear and all has been good with the odometer for two years now.
Old Nov 17, 2021 | 09:31 PM
lev's Avatar
lev
There is a lot more to a speedo than the little gear. The capacitors go bad after some years and cause the speedo/odo to stop completely or act up in various mysterious ways. Dave Barton's 240 site has a pretty complete write up about 240 speedos.
Old Nov 17, 2021 | 10:22 PM
I'll check it out! My speedometer works. Odometer is the only issue.
Old Nov 18, 2021 | 06:29 AM
jagtoes's Avatar
After 390K miles he odometer stopped working so I sent out the cluster to get rebuilt. Got it back and all works well. Now have 405K on it so hopefully it will be good for another 300K. 89 740GL one owner car.
Old Nov 18, 2021 | 08:16 AM
act1292's Avatar
Check out these links. I found them very helpful in fixing odometer problems. I had mine fail and was able to repair it myself by replacing the IIT 2115 chip in it from a donor cluster.
Electronic Speedometer Notes
1989 Volvo 240 Speedometer Diagnostic
cleanflametrap.com
Old Nov 19, 2021 | 03:54 AM
Iyoy's Avatar
Try replacing the reset ****, also available from IPD
Old Oct 25, 2024 | 01:27 PM
renardburnett's Avatar
Default Volvo, instrument, cluster repair.
I need mind fix too. Where did you get yours fixed at? I'd like to send mine in please.Advise thanks
Old Oct 28, 2024 | 04:08 PM
jagtoes's Avatar
Powl's speedometer &auto care center in Lancaster Pa. 717 898-2552
akpasta
Jan 24, 2019 07:49 AM
Shaggin240wagon
Oct 16, 2013 12:04 AM
Bmxrider07
Jul 2, 2012 12:58 PM
Rosy
Sep 11, 2010 10:14 AM
joanvito
Jul 18, 2007 08:31 PM
