How to remove a/c condenser from volvo 244
Old Jun 14, 2013 | 01:33 PM
Godfather1960's Avatar
Default How to remove a/c condenser from volvo 244
Hi again.. my next project it to get the a/c working and i did the retro to r34a went to put a can of freon in and started to leak in the middle of the condenser so i would like to know how to replace it and where is a good source to get the part from
Thanks
Brett 1984 Volvo 244 2.3L
Old Jun 14, 2013 | 03:50 PM
lev's Avatar
lev
The condenser is basically a radiator. It comes out like a radiator: you may have to take out or loosen the real radiator first, and be careful with the lines--use a two wrench technique, holding one end with one while turning the other fitting with another wrench. Use pipe wrenches if you got them.
You get a new one from all the usual parts sources, Tasca, Groton, aftermarket (China), etc. Or try a JY; they don't usually go bad and most likely you'll get a genuine Volvo part.
Old Jun 14, 2013 | 04:59 PM
great ill shop around.. would it be better if i took it in to be fixed being the system needs to be vacuumed down... your thoughts
Old Jun 14, 2013 | 10:02 PM
lev's Avatar
lev
You could get it fixed, it's a radiator, shops fix them the same way... Not a bad idea!
Old Jun 15, 2013 | 05:31 AM
great idea never thought of that ....thanks ill check into that
reidb1
Jul 6, 2008 11:17 PM
SC Surfer
Apr 22, 2008 11:29 AM
jlarma
Jan 27, 2008 10:18 AM
Turkey_Sandwich
Oct 28, 2007 08:07 PM
candodad
Aug 8, 2007 07:19 PM
