My Money Pit
Old Mar 15, 2011 | 06:05 PM
stangzylla's Avatar
Default My Money Pit
I have a 1990 Volvo 740 wagon.It's a non-turbo , but it's a regina.Since I purchased it about 6 months ago it has had a sputtering problem on take off.I used to be a volvo tech which is why I searched for a volvo but I never worked on a "regina" , I have replaced plugs , crank sensor , timing belt and seals , fuel pressure regulator , O2 sensor and a few more parts to see no remedy , if anything the problem is getting worse.I recently had to replace the resonator and found pieces of the catalytic converter in it , waqs wondering if anyone knew if the regina is sooo sensitive to back-pressure if the cat could be the cause , any ideas would be greatly appreciated.
Old Mar 15, 2011 | 07:29 PM
lev's Avatar
lev
Regina is not known for any problems in particular besides the parts being a little scarcer, and so costlier. Any codes? I'd look at other culprits for that "sputtering" problem you are having. You have done a tune up and a timing belt but there are other possibilities... fuel pressure? MAF? That coil itself (or its ground), etc...
Old Mar 15, 2011 | 07:57 PM
Titan Joe's Avatar
Make sure that there are no cracks in the dizzy cap.
p.crotty
Jul 6, 2014 08:22 AM
v70-shep
1998-2000 model year V70
May 21, 2012 11:10 AM
jeffintampa
Nov 22, 2011 09:32 PM
saibari
Sep 24, 2010 11:50 PM
2k5s40MN
Apr 19, 2008 09:45 AM
