Oil soaked timing belt?
Old Nov 25, 2014 | 11:30 PM
amccullough's Avatar
Default Oil soaked timing belt?
1985 245 non-turbo.
Just replaced the timing belt and seals, pushed the crank seal in too far. Drove, leaked oil everywhere. Took it back apart and replaced the seals because I had a second set. I did NOT have a second timing belt though, so I reused the brand new one, although it was oil soaked pretty good, but only for a short time. I've heard it's not good to use an oil soaked timing belt, but I've never understood why. Am I going to be OK using this belt or should I buy another one and take it all apart again?
Old Nov 26, 2014 | 12:02 AM
I would expect rubber soaked in oil to fail a lot sooner than rubber thats not soaked in oil.
just a gut feeling. no empirical data to back it up.
Old Nov 26, 2014 | 05:57 PM
RiceReap3r's Avatar
Is it possible to dry it out? Ive never experienced this problem, But I wouldnt risk running it in that condition. I think these engines are interference engines. Failure of the belt may cause catastrophic engine damage
Old Nov 26, 2014 | 06:23 PM
TIPSP's Avatar
Got Boost?
The 8 valves are noninterference engines. Get a new belt soon just be safe. Standard rubber doesn't like oil.
Old Nov 26, 2014 | 06:24 PM
lev's Avatar
lev
Dry it out for sure; Id wash it and scrub it with soap and water to remove the oil residue... And no, the b230 are NON INTERFERENCE engines, so nothing happens in case of belt breakage...
Old Nov 26, 2014 | 07:19 PM
Thanks all, ordered another t-belt. I have to reseat the water pump anyways, for the second time!
Old Nov 26, 2014 | 09:02 PM
RiceReap3r's Avatar
Thats good to know guys. Still better safe then sorry.
Good luck man
mrduke
Nov 22, 2022 10:45 AM
majorcode
Jan 5, 2014 07:09 PM
Mousiee
Jun 15, 2009 07:33 PM
jenzshoppin
Aug 25, 2006 09:13 PM
Qamar
Aug 24, 2005 07:37 PM
