Pre-Heat Hose
Old Jan 15, 2020 | 02:56 PM
mschultz373's Avatar
Default Pre-Heat Hose
My '85 240s pre-heat hose has severed into two pieces. I attempted to salvage it with tape but alas.
My two questions are:
1) how important is this part, particularly consider that I live in a hot climate (SE Louisiana)?
2) Is it possible to replace the pipe with some sort of piping from Lowes/elsewhere instead of getting an aftermarket/OEM part? I saw the genuine Volvo part is like $60 on FCP which is insane to me, considering it's a piece of aluminum and that the OEM pipe failed rather badly.
Thanks for any help or thoughts.
Old Jan 15, 2020 | 03:42 PM
dorvin's Avatar
I would say because you're in a warmer client where cold starts aren't really an issue, I wouldn't worry about replacing it. Unless emissions testing in your state will call you out for it being missing.
Old Jan 15, 2020 | 06:22 PM
how cold would a cold start be? We have nights that get down to just above freezing here, but that's the coldest it's ever gotten since I've lived here.
Old Jan 15, 2020 | 07:18 PM
lev's Avatar
lev
Not needed except in very cold climates... Costs about $12 from IPD if you want one...
Old Jan 15, 2020 | 07:36 PM
in fact, its a very good idea to wire the flap in the bottom of the airbox to that pipe closed, unless you live where it gets well below 0F for extended periods.
California smog testing visually inspects the hose is there but doesn't check the flap. elsewhere, YMMV.
Old Jan 16, 2020 | 12:57 AM
dytha99's Avatar
They don't emission test in central Ohio and that hose is something I always remove and throw away. Never had an issue with cold starts here during an Ohio winter.
Old Jan 16, 2020 | 05:56 AM
act1292's Avatar
I have lived in the Chicago area and had removed mine. It doesn't really help with cold starts but it does help improve gas mileage and emissions in really cold weather. I Louisiana you shouldn't need to worry about.
Frans562
Oct 12, 2013 02:41 AM
jriggs87
Sep 7, 2012 07:30 AM
rgmendoza
Dec 29, 2010 10:36 AM
tedr
Oct 20, 2009 02:11 PM
draco3
Mar 14, 2008 07:00 PM
