Transmission pan
Old Jun 30, 2023 | 09:38 AM
Psaboic's Avatar
Default Transmission pan
All,
Gotta drop the transmission pan on the 90 240 DL to replace a broken kickdown cable. There is NO way I am going to try and take the dipstick tube out at the pan as I have heard about the horror of trying to remove the nut, especially when it looks corroded (as mine does). That said, I have gotten the lower starter bolt that holds the dipstick tube on removed, but for the life of me I cannot get the top one out. No matter how many extensions, swivel joints or shallow sockets I use I cannot get a good enough angle on it. I'm going to replace the transmission mount while I am in there so I am wondering if lowering the transmission a bit will give me a better angle on the bolt.
If that doesn't work, my last resort will be to cut the tube above the elbow.
Any tips or advice appreciated.
Thanks
Old Jun 30, 2023 | 10:58 AM
Moetheshmoe's Avatar
Maybe putting a jack under the transmission, then remove the mounting brackets and disconnect the drive shaft.. And lower it just enough to give you the clearance you need.
Old Jun 30, 2023 | 11:38 AM
Simply remove the 4 bolts holding the trans cross member to provide enough clearance.
Psaboic
Jun 23, 2023 12:32 PM
BlueGiant
Oct 19, 2012 05:06 PM
daver80
Oct 3, 2009 10:55 AM
Mr_Sire
Mar 20, 2006 09:42 PM
Marks 240
Dec 6, 2005 08:48 PM
