Will an aftermarket antenna work on a '92 940?
Old Dec 10, 2012 | 07:22 AM
jdpuyear's Avatar
Default Will an aftermarket antenna work on a '92 940?
The power antenna post on our '92 340 was broken off by what can only be described as an "evil" tree limb. Regardless, can these power antennas be replaced with aftermarket stationary antennas? As an FYI, the "power" portion of the old antenna did not work either.
Thanks!
Old Dec 10, 2012 | 10:39 AM
lev's Avatar
lev
Those stationary antennas work on anything, they just pressure clamp on any sheet metal, plug into the OEM connection.
Old Dec 10, 2012 | 11:26 AM
the power antennas are actually pretty easy to fix usually. the stock whip (external part of the antenna) is quite inexpensive. you disassemble the 'snail' spiral on the motor assembly and remove any broken bits of old plastic tail. use a volt meter to verify the motor is getting power, and that the antenna control signal from the radio is getting to it, and if it still doesn't work, then you need a new motor, cheap from a pik-n-pull. on a wagon, the motor is below the lefthand floor panel, on a sedan, its behind the side carpet, its the same motor on both.
Old Dec 10, 2012 | 02:38 PM
jdpuyear's Avatar
Thanks. It is a sedan. But I am a little confused on where it is located. I was under the impression that it was in the trunk area behind the plastic siding. When you mention it is under the carpet do you mean the trunk carpet?
Old Dec 10, 2012 | 02:49 PM
ah, if your car has plastic siding in the trunk, then yeah. Its directly under the antenna, whichever. I've only dealt with 240 sedans and 7/9 wagons.
Old Dec 10, 2012 | 09:12 PM
jdpuyear's Avatar
Thanks. I am going to do the work on Wednesday. I will take some photos.
bsobo
Apr 20, 2010 08:18 PM
tboard24
Jun 25, 2009 08:43 PM
Cobra_03
Feb 9, 2009 08:49 AM
alecw81
Jan 7, 2009 05:22 PM
quarterdimenickel
Jan 29, 2008 01:38 PM
