PLAY IN STEERING RACK
Old Aug 22, 2008 | 06:18 PM
oldbug's Avatar
Default PLAY IN STEERING RACK
My '93 850 just failed state inspection due to a bad inner tie rod on the driver's side. I replaced it and still have "play" in the front end when I move the tire back and forth while on jack stands. It looks as if there may be play in the steering rack itself, but, only on the driver's side. Is this normal, or, is there a problem with the rack? Any adjustment?
Thanks,
Tom
Old Aug 22, 2008 | 06:56 PM
Default RE: PLAY IN STEERING RACK
You could also have a bad outer tie rod and balljoint.
Old Aug 22, 2008 | 08:57 PM
oldbug's Avatar
Don't think it's the outer tie rod or balljoint. I removed the power steering boot and then reassembled everything. I then moved the tire back and forth. There appears to be a littlemovement in the rack which amplifies at the wheel into noticeable movement. I would think if you had movement in the rack that it would be noticeable on both sides, but, I only have it on the driver's side???
Old Aug 22, 2008 | 09:25 PM
Then that leads me to believe it is either the outer or balljoint.
Old Aug 23, 2008 | 12:54 PM
1996850turbo's Avatar
Outer!!
Old Aug 27, 2008 | 04:16 PM
oldbug's Avatar
Hey Tech!! Looks like a bad ball joint. I'm going to have it replaced at a local shop for $125, as I need an alignmentanyways.
Thanks forthe help!
Old Aug 27, 2008 | 07:45 PM
Glad youfigured it out.
Old Aug 28, 2008 | 10:19 PM
bitter356's Avatar
Heads up out there, the steering coupler is often overlooked, with high miles, it may cause you to chase you tail. It's close proximity to the exhaust must be recognized.
alpac
Nov 25, 2024 12:31 PM
timmins
Sep 28, 2022 02:00 PM
marpelto
Dec 1, 2013 02:37 PM
scorpius
Jan 23, 2011 02:03 PM
tedv
Aug 16, 2009 01:02 AM
