Rear Main Seal Question TECH?
Old Sep 9, 2008 | 02:57 PM
1996850turbo's Avatar
Default Rear Main Seal Question TECH?
Ok,
Gonna do the rear main next week. Question is, which brand of seal should I buy?
I can get Elring from FCP for $12
But I can get Victor-Reinz or Corteco for $29-$30
Or Elwis for $23
I am thinking that even with the considerable difference in price the Victor-Reinz is the best way?? I have used MANY Reinz parts on my Volkswagen and they are great.
Old Sep 9, 2008 | 06:32 PM
Default RE: Rear Main Seal Question TECH?
bump Tech?
Old Sep 9, 2008 | 06:34 PM
I always go OEM it would be best to buy an OEM.
Not sure who makes them though. They always come with a felt strip on them from the dealer hiding the info.
Old Sep 9, 2008 | 06:37 PM
Yeah,
One place I order from says that Rienz is OEM supplier. I think I will go with them.
Old Sep 9, 2008 | 06:57 PM
That would be the best.
I have never had any problems at all with them.
Old Sep 9, 2008 | 08:29 PM
bitter356's Avatar
Not only OE part, how about seal installation?
Old Sep 9, 2008 | 08:51 PM
ORIGINAL: bitter356
Are you asking if there is a special tool?
Old Sep 9, 2008 | 09:07 PM
bitter356's Avatar
My point. Seen best efforts spoiled by botched install. Which should be viewed just as important as vendor.
Old Sep 9, 2008 | 09:10 PM
Yes if done right any seal can be installed without any special tools.
Half the time I don't use the tool anymore because even though it is pretty new it still doesn't work right all the time. It is a 2 piece tool but sometimes I guess it goes a little crooked and doesn't sit perfect.
Old Sep 14, 2008 | 07:11 PM
What is the best way to do it without the tool? I am assuming I could tap in?
Old Sep 15, 2008 | 04:40 PM
Yes you can tap it in easily. But make sure the inner lip goes over the crank shaft when installing the seal. I have seen people roll the seal installing it.
Old Sep 20, 2008 | 09:10 PM
Turconator's Avatar
When i had to do my rear main seal on my 93 850, i used a small screw and a screwdriver. With the screwdriver drive the screw into the old seal and thentook it out with a pair of sidecutters to get into the small gap. (Should come out fairly easy) then I placed the new one in and lightly taped it in with a flat head scredriver. That's how i did mine and i haven't had any leaks.
Good luck with it
LOVEvolvos
Aug 30, 2012 01:22 PM
oreng
Jul 20, 2010 03:22 AM
jcmartin
Sep 20, 2008 09:19 PM
850Sleeper
Oct 3, 2006 09:16 PM
anubyss
Nov 2, 2005 11:47 AM
