replace alternator
replace alternator
i cant tell if its the alternator making this humming/squealing noise but its coming from that area. its most noticeable when applying gas at a standstill or when shifting through the first 2 gears it stops after some speed is gained. when i turn the key to off the battery light flashes for an instant. when accessories are turned on the headlights dim a bit, it obvious the battery does not hold a charge that long, like if i left the lights on for 5 min id need a jump. when i disconnect the battery after started (i heard this was bad to do after i did it) she keeps on running. the battery is also undersized but dont know if any of this would cause the alternator to squeal. please point me in the right direction almost at stage 0 cant seem to get there something else allways crops up to bite me.
everyones has a different idea as to what part is failing no two sources agree. i believe after more poking around the belt accessory tensioner is the culprit producing this whining sound. obviously i just don't want to jump in and replace it so im thinking of a way to test it. im 90% sure
oreng
04-09-2019 02:17 PM
