C70 Crank Pulley lightweight
Old Apr 12, 2009 | 08:40 AM
ICE's Avatar
ICE
Default C70 Crank Pulley lightweight
http://cgi.ebay.com/ebaymotors/Volvo...Q5fAccessories
Hey guys, see the link above, a friend of mine with an Opel astra has fitted the same kind of thing to his car and said it increases performance by 7-10 HP, i mean I know its not that much but he is now squeezing as much as he can out of his car so every little bit helps right ?!
im wondering if having this will make any differerence to me. Does this pulley create less resistance resulting in more torque, quicker spooling as it says in the add ?
Old Apr 12, 2009 | 08:45 AM
I'm not sure I have wanted to try one myself.
I had sent one (OEM)to a member in Canada awhile ago and he was going to have a friend make a few and send me one to test but I never heard anything back from him.
Old Apr 12, 2009 | 01:03 PM
ICE's Avatar
ICE
hmmm, the 850 shown in the link will fit my 98 C70 wont it ? same engine ?
oh and is it costly to install ?
Old Apr 12, 2009 | 01:15 PM
Yes they are the same engine.
Easy to install.
Old Apr 12, 2009 | 01:22 PM
ICE's Avatar
ICE
Easy to install.
Cheers Tech, ill decide in the coming weeks whether ill do it and let you know the results
Old Apr 12, 2009 | 01:23 PM
ICE's Avatar
ICE
any idea where i could get one for cheaper ?
Old Apr 12, 2009 | 01:26 PM
PANTYEATR's Avatar
the only problem i have with it is that it doesn't say that it's an underdrive pulley. it just says that it's light weight and stock diameter. an underdrive would not make power but free up rotating inertia and slowing down your accessories i.e. P/S, ALT and A/C. an underdrive would also require a smaller belt.
Old Apr 12, 2009 | 02:10 PM
ICE's Avatar
ICE
ok so its hardly worth it then after buying a new pully and belt ?!
pfft i need some sleep...5am here, damn Augusta is keeping me up
Old Apr 12, 2009 | 02:44 PM
PANTYEATR's Avatar
see if unorthodox racing has an underdrive pulley available.
Old Apr 12, 2009 | 07:14 PM
The difference in weight will be atleast 5-10 LBS in the pulley alone.
The stock pulley is very heavy.
Old Apr 12, 2009 | 10:44 PM
ICE's Avatar
ICE
Just had a look at unorthodox racing and they dont even do Volvo. will keep looking elsewhere.
Old Apr 18, 2009 | 04:09 AM
C70's Avatar
C70
I had the Unorthodox Racing light weight pulley installed a month ago, seems like the engine revs alittle easier/no other noticeable performance differences so far. The stock pulley is about 9lbs very heavy compared to the UR pulley 1lb. Personally i would recommend it after getting stage 0 completed,as i did. I think it would be more noticeable after ecu upgrade.
Old Apr 18, 2009 | 12:09 PM
reg's Avatar
reg
The reason MFG's use a heavy pulley is to smooth out vibration.
r.
Old Apr 19, 2009 | 12:34 PM
PANTYEATR's Avatar
well i have almost solid engine mounts anyway so vibration isn't a care of mine.
i know i saw some volvos with an UDP form unorthodox.
ZaphodBblbrux
Jul 2, 2012 09:54 PM
guest01
Nov 5, 2011 10:11 PM
dbheatherly
Nov 27, 2007 06:24 PM
Reilly_S70GLT
Sep 5, 2006 08:57 PM
whyflygti
Oct 4, 2005 01:23 AM
