Driver window issue
Old Oct 5, 2018 | 04:40 PM
Cwarr1120's Avatar
Default Driver window issue
Driver side power window just dropped, will not go back up. All other windows and locks work. My first Volvo. I've seen this on D13 trucks i drive at work
Old Oct 7, 2018 | 05:07 PM
sounds like the window regulator or the guides have failed or the bolts came lose. You need to pop off the door card to have a look. What year and model do you have?
Old Oct 8, 2018 | 07:41 AM
Cwarr1120's Avatar
Default Driver side windows nor working
2001 S60 . Did that regulator was fine. Thinking it's the switch section of DDM
Old Oct 8, 2018 | 09:35 AM
do you get a voltage drop when actuating the switch? could be the motor failed, relay (circuit breaker?) or the switch if the regulator and rails looked ok. Sounds like you are on the right path.
Old Oct 8, 2018 | 12:40 PM
Cwarr1120's Avatar
Default Window
Going to dealer Wednesday will find out for sure then
gatorloverone
Dec 18, 2008 09:07 PM
02VolvoS40
Feb 4, 2008 06:05 PM
burnferris
Nov 1, 2007 09:27 AM
my3sons
Jan 21, 2007 09:44 PM
xoneinax
Sep 14, 2006 10:28 PM
