A\C comming on while the car is off?
Old May 25, 2005 | 03:14 AM
kaltek's Avatar
Default A\C comming on while the car is off?
this 1 really is perplexing
On a hot day i have the a/c running and the pull the car into my garage. About an hour or two later the car is not running but the vents in the car are running WITHOUT THE KEY IN. Its almost freaky to watch. to get it to stop i have to turn the car on and off again. So whats going on? Is it a electrical problem or what?
Old May 25, 2005 | 03:52 AM
will/bill's Avatar
Default RE: A\C comming on while the car is off?
simple your car is equiped with a system called afterblow what this does is if the car has run with the a/c on inc. the defroster. at approximately 55 min. after the car has been shut off key out will turn on the climate control fan(app. ten min) to clear any moisture from the ac ducts to prevent mold from forming (musty smell) function can be turned off with the vadis/vida (dealer diag system) but is not rec.
Old May 25, 2005 | 09:40 AM
The Aftreblow kit is good to have and will save you money in the long run.
Old May 26, 2005 | 04:19 AM
eli's Avatar
eli
I noticed that my S80 did this once. I thought there was something wrong with it. So is this "afterblow" kit an option? I take it that the climate control is just programmed to do this.
Old May 26, 2005 | 12:56 PM
Yes they come with it.It is programming in the module.
It can be turned off but then there is a chance that mold will grow on the evaperator.It is designed to keep the evaperator dry so mold can't grow.In the long run it helps make the evaperator last longer as well.
Old May 26, 2005 | 04:55 PM
familyman's Avatar
great! I was cleaning the inside of my windshield when it came on and started blowing, I didn't know what had I done. And then one time I was washing the car and heard it come. I figured it was something well thought out.
Old May 27, 2005 | 03:22 AM
eli's Avatar
eli
It seems like a good feature to have, as long as it doesn't drain the battery.
Old May 27, 2005 | 01:03 PM
It doesn't stay on long enough to kill the battery.
Old May 27, 2005 | 05:40 PM
Ck8's Avatar
Ck8
Tech
It has been a hot day today and when I stopped the car I did not notice whether the fan or the a/c was still on, but 45 mins later I noticed the fan was on when I got into the car before I put in the key.
So this afterblow option did it come as standard on the S80 which and programmable to the climate control? How come if the A/c stays on for 45 mins it doesn't drain the battery? Why it had not come on before only today the hottest day so far this year? Should it come on every time the A/c has been on?
Kind regards
Old May 27, 2005 | 06:30 PM
It is programmed to come on after the A/C has been run.It comes on between 15-30 minutes after the car has been run.It runs for I believe 10 minutes then turns off.
Old Jun 27, 2005 | 01:55 AM
lorawms's Avatar
I have had the same problem. I would love an answer also!!!!
Old Jun 27, 2005 | 02:57 AM
ORIGINAL: lorawms
Which one do you need an answer to?
Old Aug 18, 2005 | 08:01 PM
5150PhD's Avatar
Man I knew I should have came to this forum sooner (been in the nation harley truck owners for some time and that's been invaluable). I had heard bad stories regarding the electrical systems in volvo's and just thought that the fan blowing after the car turned off was just a faulty swtich.
Thanks Tech!!
Old Sep 23, 2005 | 12:22 AM
EmailBenn's Avatar
Afterblow, so that is what that is, I just thought something else was wrong with my car.
VolvoLover2011
Mar 23, 2013 04:27 PM
rvinson2
Jul 27, 2009 09:21 PM
mischief4l
Apr 1, 2009 10:09 PM
mr.mudd
Jun 1, 2008 07:58 AM
James0013
Aug 5, 2007 07:47 AM
