2000 S80 door panel
Old Dec 19, 2009 | 11:51 AM
parrothead71's Avatar
Default 2000 S80 door panel
Ok I am doing some work on an S80 for a friend. One of the things I need to do is pull off the left rear interior panel but I am not sure about those plastic rivets. Do I just push in the center pin and dig it out of the door and re-use or do I break and replace them? The problem I need to fix is with the door lock. You have to manually lock and unlock the door as the power option has stopped working. When the lock is pulled up or pushed down I can here the actuator working it just won't unlock or lock the door. Any ideas?
Thank you,
Paul
Old Dec 19, 2009 | 12:26 PM
Yes push the center in you will feel it click. Then pull the entire clip out.
About the door lock usually that is the assembly being bad.
Old Dec 19, 2009 | 01:10 PM
Thanks I will check it out.
mk2sprite
Mar 30, 2021 01:45 PM
jrcochranusa
Feb 19, 2010 02:30 PM
vy22
May 10, 2008 06:34 AM
1999S80T6
Oct 13, 2007 01:20 PM
daisydaisy
Jan 9, 2007 08:48 PM
