Took the 01 XC70 to the dealer
Old Apr 1, 2009 | 01:00 AM
mcbalagtas's Avatar
Default Took the 01 XC70 to the dealer
My reader was getting the ECM-9150 which indicate the ETM. From several post, I was told this should be covered under warranty, so I brought it in.
I took it in a 0700 and waited until 1400 to call for an update. They said the tech was still looking at it and needed to call Volvo to further diagnose the problem and wouldn't know anything until tomorrow. Seems kinda odd they wouldn't know what to do since they extended the warranty for the ETM.
I guess I'm a little anxious they will try and tell me it isn't the ETM and not covered. What should I do if they did?
Old Apr 1, 2009 | 08:24 PM
Hopefully it will jut be covered.
Old Apr 2, 2009 | 08:04 PM
mcbalagtas's Avatar
Well, the dealer called and said it was covered and had it fixed already. I'm happy for once.
Once I hit 100k, the 2 biggest 'gotchas' that I researched before I bought the car - Xmission/ETM lit up my dash. The xmission seems fixed for now after flushing and the ETM was fixed under warrranty....I feel like I dodged 2 expensive bullets.
I don't feel so bad about the little things now
- dealer says rear rotor/pads need to be replaced
- radiator hose under reservoir leaking [found doing timing belt]
- radio changing channels on it own...usually up 1 station
- engine mount center/front/bottom leaking
- PS CV joint leaking grease....not torn though
- spun bearing on Angle gear.....ok this one is expensive
Old Apr 4, 2009 | 08:58 AM
Well glad it is fixed for the most part and was covered!!
robrike
Nov 11, 2007 12:37 PM
volksnut
Jun 8, 2007 05:01 PM
fredgold52
Apr 13, 2007 05:38 AM
lamski
Mar 2, 2007 03:04 PM
