ac blower fan
Old Sep 3, 2008 | 04:24 PM
ktkamm's Avatar
Default ac blower fan
For the last 6 weeks or so the blower fan on my AC will stay on for prolonged periods after the engine is shut off. In order to kill it, I have to pull the fuse. My wife also says that when driving the car for an hour or so, the ac blower works erratically. The only thing I can trace the problem back to is when I gave my dad's car a jump start. I am afraid I fried something. Any and all help to remedy this would be much appreciated. At my "last" service check at the dealer where it looks like they topped off fluids, etc for a mere $600+, they did look at the AC and said nothing was wrong. Needless to say, my wife was neither impressed or pleased. Thanks in advance. Kieran
Old Sep 3, 2008 | 07:47 PM
Default RE: ac blower fan
I would say the resistor is bad.
Old Sep 3, 2008 | 07:56 PM
ktkamm's Avatar
Thanks for the quick reply. Is replacing the resistor a difficult thing to do. I don't mind a bit of a challenge, however, I would leave a more involved job to a mechanic.
Old Sep 3, 2008 | 07:58 PM
What year is the car?
Old Sep 3, 2008 | 08:14 PM
ktkamm's Avatar
2004 xc 70
Old Sep 3, 2008 | 08:23 PM
You have to pull the blower motor out and the resistor is in with the blower motor.
Old Sep 3, 2008 | 08:28 PM
ktkamm's Avatar
I am ignorant as to what pulling the blower motor entails, however, sounds like it may be a large job and one I may want to defer to a local mechanic. Thanks for the input.
Old Sep 3, 2008 | 09:14 PM
It isn't that bad. Remove lower dash panel 2 screws. Then look for the black blower motor. You will also have to remove the glovebox to get the motor out.
Old Sep 4, 2008 | 05:21 AM
ktkamm's Avatar
Thanks. I think I will go ahead and give it a try. Is thrre any way to test the resistor before odering a replacement. I have an ohm meter. Thanks again for the help.
Old Sep 4, 2008 | 08:29 AM
ktkamm's Avatar
In follow-up, I had my old mechanic look at it. He has an aftermarket code reader. No codes showed up as abnormal in the climate control, etc., area. Pulled some relay in the passenger side foot compartment which appeared to be the relay for the resistor. seemed to have very briefly reset things. He thinks it is probably best to bring it back to the dealer. Any additional thoughts?
Old Sep 4, 2008 | 06:51 PM
I haven't really messed with the Ohm readings for the resistor. It is just a common thing usually there is codes leading to it.
An average scanner cannot read climate codes on these cars.
Old Sep 4, 2008 | 08:33 PM
ktkamm's Avatar
I broke down and brought it to the dealer today. They will be replacing the resistor. I hope that is the issue. Thanks again for your help.
Old Sep 4, 2008 | 08:44 PM
I am 99% sure that is the problem. Yes please let me know how you make out.
Volvo850GLTOwner
Oct 10, 2012 10:08 PM
evpridgen
May 21, 2011 04:59 PM
jmallie
Sep 17, 2009 09:47 AM
mooser
Jun 16, 2006 12:09 AM
twilliams1223
Mar 4, 2006 10:16 AM
