Slight almost very bad mishap today
Old Aug 2, 2016 | 11:21 PM
noruckus's Avatar
Default Slight almost very bad mishap today
I'll try to keep this short, driving to a destionation today the air conditioning went out, meaning stopped blowing cool air about 2 miles from where I was going, upon arrival after parked smelt a bad burning order with slight smoke from engine bay, popped the hood and more smoke, sparks, smalll flames coming from what I belive is the air compressor unit/pump, unit up high drivers side run by fan belt, blew on flames a few times all went away except smoke. A couple of minutes after the fan belt broke/seperated. All while parked.So obvisouly 2 issues, fan belt and compressor or altenator,
1st ,opinions of this.
2nd, has 90.000 miles, if these are to be replaced what other items need to be adressed at the same time? idler pully, belt tensioner, water pump? What about timing belt or is that the same as fan belt.
Getting towed in the AM to shop, would like to be able to direct mechanic as to what I might also want done beyond what is suggested to me.
Thanks, Mike.
Old Aug 3, 2016 | 01:02 PM
Smith Volvo's Avatar
Banned
here are some prices and exploded view PDF'S so you have some ammunition. I'm guessing either a pulley or compressor seized up
36051068 COMPRESSOR 1 1 0 929.30 $670.62
31251046 BELT 1 2 0 85.19 $46.00
31401286 BELT TENS 1 0 0 136.49 $74.37
31401193 IDLER ROL 1 0 0 91.12 $49.20
File Type: pdf
File Type: pdf
Old Aug 3, 2016 | 09:13 PM
noruckus's Avatar
Thank you Smith , conformed today it is the air compresor, no quote yet but was told expencive.
back to an origional question, are there other replacements that should be done at the same time on a 90,000 mile car
koko284
Mar 15, 2012 05:30 AM
JondevieonS40
Oct 12, 2011 07:06 PM
Capo Cam
Feb 1, 2008 09:06 AM
